#1 need help with wireing
baldy Posted on: 2009/8/29 11:07
Can anyone tell me what colour wires are on the ballast resistor for the coil on a 71 1200 sedan I have one with a black and white with a red and blue connected together and the other is just a black and white wire . When you turn the ignition on they both have power I thought there would only power in one as it went threw the resistor to the coil. I have found this is why my tacho isn't working .any suggestions
#2 Re: need help with wireing
tommo73 Posted on: 2009/8/29 16:21
hope this helps
jpg  B110%20Wiring.jpg (101.67 KB)
10243_4a9947586c34b.jpg 902X737 px
#3 Re: need help with wireing
ddgonzal Posted on: 2009/8/29 18:03
I don't think that'll prevent the tachometer from working.
The resistor and coil with both may have power when key is to START, but resistor alone when key to IGN. There is a table showing color wires in Wiring::Coil
#4 Re: need help with wireing
baldy Posted on: 2009/8/30 9:20
Thanks for the help fellas it is now sorted with your help . tacho working as well.
