#1 engine mount brackets
Gurners Posted on: 2009/10/8 3:18
Just bought a 1200 coupe as I've finished my 1000 coupe. My mechanic says the engine mounts are totally bent. He says they should be straight up from the cross member. At the moment they bend towards the front of the car then straighten and everything engine/radiator wise looks in the right spot. Any help?
#2 Re: engine mount brackets
andy-roo Posted on: 2009/10/8 3:21
wot year is it? wot engine does it have in it? it may have home modded engine mounts to account for a early -late model engine swap??
pics would help
#3 Re: engine mount brackets
PIGDOG Posted on: 2009/10/8 3:30
nah the engine mounts on the crossmember are supposed to go forwards a little bit
mount bolts on about 2 inchs forward of the centre line of the crossmember
#4 Re: engine mount brackets
andy-roo Posted on: 2009/10/8 3:33
woops my mistake i read it wrong
#5 Re: engine mount brackets
bert Posted on: 2009/10/8 4:02
Pigdog is spot on they go forward about 2" from centre line.
You gotta watch some of these so called"mechanics"unless there old school they would'nt know half the time.
Cheers
#6 Re: engine mount brackets
ddgonzal Posted on: 2009/10/8 4:49
This is the factory 1971-1973 Datsun 1200 (Coupe, ute, sedan, wagon) mounts:
the two bolts are where the crossmember is, motor mounts look about 2" forward, as already stated.
larger pic Left larger pic Right
1974-up are different.
#7 Re: engine mount brackets
Gurners Posted on: 2009/10/8 7:24
1970 model. Standard A 12 engine with no mods at all. From all the fantastic feed back it appears they do go forward so now I can tell my mechanic he doesn't know everything. Thanks heaps.
#8 Re: engine mount brackets
PIGDOG Posted on: 2009/10/8 9:26
how could you think they are bent though...the mount surface would still be flat with the block mount. and all the bends are nicely pressed smooth bends
tell your mechanic to not give up his other day job
#9 Re: engine mount brackets
DattoFrog Posted on: 2009/10/8 14:24
SOME MOTHERS DO AVEM' Let me see if I have it right; Acne, cap on backwards and drives a VL Dunnydoor is my guess!
