Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Please Help me to clarify some unclear areas
Sumith
Posted on: 2009/10/15 6:58
Hi Guys
Just Give me b210 Wiring Diagram if any one has or just post me the link from where i can get it Thanks Regards Sumith
#3
PLease Help me to clarify these
Sumith
Posted on: 2009/10/15 7:37
Hi Guys
Just going through the wiring article and there are some unclear areas for me , please help me .ill post them on thif discussion Thanks Regards Sumith
#4
Re: PLease Help me to clarify these
Sumith
Posted on: 2009/10/15 7:42
Hi Guys
IG (ignition/run) This connects to two things: * Directly to Ballast Resistor (non-coil side). This is spelled "Resister" in some Nissan publications. If equipped with optional factory tachometer, this circuit goes through tachometer Means this wire connection is going to the ignition coil negative side what they mean by Ballast Resistor ? clarify me in simple way please Thanks regards Sumith
#5
ROConnor
Posted on: 2009/10/15 7:57
Its a white block with a wire coing out iether end neer the distributer. its not nesicery with elctronic ignitiom
#6
Posted on: 2009/10/15 7:58
what they mean by Ballast Resistor ? ![]() Remember the article is about Datsun 1200 (B110) unless otherwise stated. But B210 is similar. Wiring colors may differ. Tachometer wiring may differ.
#7
Sumith
Posted on: 2009/10/15 8:06
Hi Guys
OK clear ,means it has got 2 connectors (coil side and non coil side) isn't it ? Thanks Regards sumith You can view topic.
