#1 Disc + Booster/Master Combo Question ??
DatsAndy Posted on: 2009/11/1 1:45
So we are planning to run 13's (steelies) on Mr hanky My idea is 1200 coupe struts with discs up front and i have some factory looking brackets to run different calipers on them, (Think we worked out at tommos they are off 120y panel van cause they came with other 120y stuff) and bluebird discs on rear (if 13's will fit on them)
What booster/master would be better Sunny setup or 180B with 1200 master on it ?. Thanks in Advance.
#2 Re: Disc + Booster/Master Combo Question ??
DatsAndy Posted on: 2009/11/1 11:14
Bump
#3 Re: Disc + Booster/Master Combo Question ??
ddgonzal Posted on: 2009/11/1 16:35
The sunny setup would be better. Additionally, fit a proportioning valve to set the balance between front and rear brakes.
#4 Re: Disc + Booster/Master Combo Question ??
supafatto Posted on: 2009/11/3 6:29
would you like my setup?
