#1 octane booster
iDatto Posted on: 2009/12/7 0:40
hey got a quick question
whats octane booster gunna do to my engine,
wont hurt it or do anything bad will it?
thanks guys
#2 Re: octane booster
iDatto Posted on: 2009/12/7 0:41
its an a12
#3 Re: octane booster
hotrocket Posted on: 2009/12/7 0:55
when i had my a12 before the ca18det, for about 12mths i was using Vortex95 (95.4) now and again with E10unleaded (94.5)...witch didnt hurt it,
the normal ULP is (91.6)Caltex
hope this helps in sumway...
#4 Re: octane booster
perthute Posted on: 2009/12/7 1:00
theres a a few different types i only use them when i go drag racing ( wonce a year ) neva had a problem but wouldnt use it every day has i buy the one thats $30 . and i dont think its good for your car guess it has the same stuff in it has areo start ( i blew a hole in my piston from using it )
#5 Re: octane booster
perthute Posted on: 2009/12/7 1:02
bp 98 only for me even in the xtrail pulsar n lawn mower
#6 Re: octane booster
iDatto Posted on: 2009/12/7 1:44
haha, the one i saw was stp
tryed that before?
i put it in my swift and it was backfiring heaps
#7 Re: octane booster
perthute Posted on: 2009/12/7 2:01
yer could need the timing changed but use good 98 fuel and mod the car its cheaper in the long run then paying for octane booster every tank ;)
#8 Re: octane booster
LittleFireyOne Posted on: 2009/12/7 2:19
In my opinion if your car isn't running high enough compression and it's not tuned for it then don't use it because your varying the effectiveness of your tune by:
- running richer
- placing more stress on piston rings because the amount of fuel is denser and more resistant to ignition
- the amount of octane booster will vary with the fuel, how could it possibly mix through the whole fuel tank evenly?
#9 Re: octane booster
1000Coupe Posted on: 2009/12/7 4:49
unless your compression is 10:1 or above u dont need any more octane than 91ron (regular unleaded) if u want to up the octane for higher compression then use 95 or 98, to up octane by putting octane booster in u need to use a can and shake it properly, thats fair enough for racing when u have a small tank but not practical for 50L or more in your car.
to get it anywahere near properly mixed in your car at the bowser u need to put in a dash pump in 10L add a dash, pump in 10L, etc.
VP race fuel or adding octane booster up to 104 will not hurt the engine unless its not mixed in properly, but wont get u any more power unless u have the extra compression and advance timing tuning.
#10 Re: octane booster
mcgee Posted on: 2009/12/7 5:53
1000coupe,
That rule of thumb might be good for NA cars (not willing to comment on that aspect) however with turbos you can tune for a few more degrees timing with octane booster. I had my CA tuned for 98RON and we pushed it even harder with some octane booster. This was around/over 22psi which I don't normally run on the road but often down down the 1/4 mile, for me it's a bit more of insurance when pushing the engine hard - not for every day use.
Bryan
