#1 Strut insert...
ronald_loulan Posted on: 2009/12/10 2:19
I swapped b310 suspension set to my b110 4drs...
Wat kind of strut insert tat is harder n shorter tat will fit the strut?
Thanks in advance...
#2 Re: Strut insert...
racetech Posted on: 2009/12/10 5:51
Have a look here, a lot of info that helped me, http://datsun1200.com/modules/mediawi ... Strut_Insert_Part_Numbers
#3 Re: Strut insert...
ronald_loulan Posted on: 2009/12/10 6:12
I check tat b4...
I install a pillowball mount with adjustable height n custom lowered spring...
Even i adjust lowest coz when i put pillowball,it will increase the height bout 2 inch..
Now im running on the bump stop all the time...
jpg  untitled.JPG (28.31 KB)
9396_4b2091cbdb061.jpg 615X377 px
#4 Re: Strut insert...
PIGDOG Posted on: 2009/12/10 7:38
common ones to fit are 240z, r31, z31. even shorter than that are st150 corrona inserts and i think there are were another 2 inserts that were shorter than the corrona ones when i asked pedders
#5 Re: Strut insert...
ronald_loulan Posted on: 2009/12/10 7:45
I heard tat Toyota Starlet's will fit too...
Isit??
#6 Re: Strut insert...
racetech Posted on: 2009/12/11 7:50
What I did:
I sourced a catalog (Monroe in my case) and started looking for what will fit and has the desired travel needed.
#7 Re: Strut insert...
PIGDOG Posted on: 2009/12/11 7:52
yeah just go to a suspention shop and have a look through the inserts that are available for the tube size you have
