#1 Wanted: CA18DET odd bits
1200rallycar Posted on: 2009/12/14 10:47
Wanted, parts to complete my CA18DET setup:
Loom - Engine
Starter Motor
Oil line to feed turbo from block
Gearbox shifter for skyline stumpy
Rubber engine mounts
#2 Re: Wanted: CA18DET odd bits
bailz Posted on: 2009/12/14 12:31
rubber engine mounts, you mean like maddat ones? if so go for landrover V8 ones off ebay..
shifter is just standard ca18det shifter for the stumpy box..
starter motor better to buy a new one to be honest, there gettin old now.. saves having to pull whole engine out later...
#3 Re: Wanted: CA18DET odd bits
PIGDOG Posted on: 2009/12/14 13:07
i'll also add that im after a pair of CA exhaust valves, dont really want to pull my rebuilt head apart for them if i can help it
think he means like standard CA18 rubber mounts, R31 like i said are good and plentiful at wreckers
CA18det shifter wont work in a stumpy box...completely different design
can however use A series shifters in them if you redrill the pilot hole. or other later model L series and Z series shifters are the same...didnt check if i had a spare shifter. should have the stock one around for it somewhere
and you shouldnt have the pull the whole engine out to do a starter bailz....not like there is really anything else down there stopping it from getting out when the engines in the bay
#4 Re: Wanted: CA18DET odd bits
1200rallycar Posted on: 2009/12/15 2:07
yeah the loom is the real show stopper
got to get my hands on one of them
starter motor i was thinking of getting a rebuilt one if neccessary
any tips on buying a clutch for it? i remember they were quite expensive for SR but havent priced a CA one yet
#5 Re: Wanted: CA18DET odd bits
bailz Posted on: 2009/12/15 3:45
my bad, the stumpy box does have different shifter lol.. new starter motor from repco is like 250 so its easier to get brand new...
loom, i could possibly get ya a loom if ure desperate, theres a few in WA
#6 Re: Wanted: CA18DET odd bits
PIGDOG Posted on: 2009/12/15 5:06
think i payed like $20 for my starter motor...seems to be doing fine
loom can be done later once everything is in the car, ive got wiring diagrams if you need them
clutches for CAs are also expensive, extreme ones are apparently the way to go as exceedy are still pretty expensive
think for a HD 5 puck they are like $700 ish new for the extreme, got one that was a year old for $300 and it seems to be ok
#7 Re: Wanted: CA18DET odd bits
bailz Posted on: 2009/12/15 5:50
murphys law, what can go wrong will go wrong.. essential parts i would go for new or near new/recon..
starter motor, alternator, timing belt, water pump belt.. basically do a major service on it b4 hand or u will loose interest pretty fast when ya car wont start and u have to pull the motor ;)
#8 Re: Wanted: CA18DET odd bits
Mildman Posted on: 2009/12/15 5:56
I might have the std engine mounts around....I'll dig around see what else there is.
I should have a computer (Engine ECU) as well - assuming both the ones I've got work.
#9 Re: Wanted: CA18DET odd bits
D Posted on: 2009/12/15 6:04
Any chance you can use the starter from the ca20????
otherwise Id be interested in a billet one for a group
buy or something similar.
RC you going ca18 finally which car?
#10 Re: Wanted: CA18DET odd bits
bailz Posted on: 2009/12/15 6:56
i have a starter motor, an engine mount not sure which one,i have 3 ca computers, one mines tuned and few othern bits if ure desperate
