Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
DCNF Jetting/setup
ronald_loulan
Posted on: 2010/2/18 1:58
Hi guys,im wondering wat DCNF jetting u guys uses for ur moded or std engine? Juz for reference for every1.
Engine Specs Nissan Vanette C20 A15 1500cc Australia Regrind Cam 270⁰ 6.5mm Lift (Stock 240⁰ 5.5mm) Skimmed Head 0.5mm Wider Valve Angle (3⁰ - 5⁰) Std valve clearance spec (Cold 0.30mm) Fuel System Weber DCNVA 36 Main Jet = 125 Air Corrector = 200 Emulasion Tube= F24 Pump Jet = 50 Idle Jet = 45 Auxilary = 3.5 Choke = 26mm Japan Fuel Pump 4psi (Build in regulator) Ignition System MSD Blast 2 Racing Coil Performance Plug Cable (Low Resistance 2k ohms) IK20 Iridium Plug A15 Electronic Dizzy Ignite at 12⁰ BTDC without vacuum port Exhaust System A15 4-2-1 Extractor 1.6” Piping 2 Center bullet Rimus Muffler
#2
Re: DCNF Jetting/setup
Posted on: 2010/2/18 4:29
wat DCNF jetting u guys uses We don't use DCNF carburetors, not sure if any club member does.
#3
ronald_loulan
Posted on: 2010/2/18 4:48
i think most of the members uses twin Dcoe or Dhla...
#4
Posted on: 2010/2/18 5:05
Or PHH40s like is the favorite in Japan.
Or Weber DGV, which is a favorite in USA and Australia.
#5
benny
Posted on: 2010/2/18 7:27
DCNF weber's are much like an IDA or IDF weber. they are a dual throat synchronous downdraught carb. I have a pair of 40DCNF's i want to try on an A-series at some pont. As for jetting i would reference the calcs and charts used to determine the jets used in DCOE webers.. I think it would give you a good starting point or baseline.
Also an added bonus for there use, would be on LHD B110 models, i reckon they would clear the brake master cylinder. benny
#6
ronald_loulan
Posted on: 2010/2/23 13:37
DD,in Malaysia most ppl uses DCNF(performance) or DGV(Spirited Driving)..
For racing or drifting,we use DCOE or DHLA or Solex... :) Benny,y dont u use twin side draught?? Coz they cant clear the brake master cylinder??
#7
LittleFireyOne
Posted on: 2010/2/23 14:50
all of his are RHD, I'd say it's an exercise in alternate performance possibilities. And why not, they're a compact little jigger that packs enough punch for Ferarri
