#1 WTB - 79-85 1200 Ute Radius Rod Mounts same as HB/PB 210
thedevilshands Posted on: 2010/5/26 6:39
As per title, cant seem to change the title in the other thread I posted
Need radius/caster/castor rod mount (lil sheet metal box thing the rod goes through and bushes on either side at front of car)
Any one got a ute from that era they are wrecking or HB210/PB210 (Sunny Excellent)?
Many thanks, Jon
#2 Re: WTB - 79-85 1200 Ute Radius Rod Mounts same as HB/PB 210
ddgonzal Posted on: 2010/5/27 9:30
I was looking in the parts catalog
Bushings are the same 1200/B210/B120. B210 has part number for bracket, while 1200s do not (must be sold as part of the body piece?).
So I think you can fit the B210 bar in a 1200. When mine broke on my 1200, the body shop (panel beater) made a new one out of sheet metal and welded it right in place.
#3 Re: WTB - 79-85 1200 Ute Radius Rod Mounts same as HB/PB 210
thedevilshands Posted on: 2010/5/27 10:18
Thanks DD, I think I might be asking a bit much. As you say the mounts will have to be cut off the body, so its really bits off wrecks that I'm after.
I'm chasing these mounts because they create a different angle to the aussie B210 ones.
Apparently the L series PB210 from japan used these mounts with 180B/610 radius rods to balance the weight of the heavier motor on the 180B x-member in the B210 chassis ("davie" kindly provided this information).
Any one got any thoughts or wrecks?
Cheers, Jon
#4 Re: WTB - 79-85 1200 Ute Radius Rod Mounts same as HB/PB 210
thedevilshands Posted on: 2010/5/27 15:37
was gonna bump bogdog's L20B stroker thread cos that engine look schweet!!!
BUT...
Come on someone gotta have a 79-85 ute wreck they wanna cut the radius mounts off??
Anyone??
Lol
Bump ;)
#5 Re: WTB - 79-85 1200 Ute Radius Rod Mounts same as HB/PB 210
estyre Posted on: 2010/5/27 16:12
have you tryed grand auto wreckers they would probably have a ute there or would know were to get the mounts
hope this helps ,and the L20b stroker is pretty sexy !
#6 Re: WTB - 79-85 1200 Ute Radius Rod Mounts same as HB/PB 210
thedevilshands Posted on: 2010/5/28 2:38
thanks mate I'll give em a call n see what they got.
