#1 Fuel Tank Has gt a Tiny Hole
Sumith Posted on: 2010/7/2 5:14
Hi Guys
I was cleaning my fuel tank before carburetor job to be done
so notices that there is a very tiny hole near the drain plug
what would be the solution went to a the mechanic he said not needed to weld it tube of areldite will solve the problem
what is your suggestion ?
Thanks
Regards
sumith
#2 Re: Fuel Tank Has gt a Tiny Hole
ddgonzal Posted on: 2010/7/2 5:52
Yes, it can be fixed without welding. But if there are other holes waiting to break out (due to rust or corrosion) then it is a temporary fix.
Araldite is a brand of adhesives. Probably he means the Araldite two-part expoxy.
They use it to hold up the Sydney Opera House so I reckon it would work for a fuel tank.
#3 Re: Fuel Tank Has gt a Tiny Hole
DatsAndy Posted on: 2010/7/2 6:06
Another tried and proven temporary fix is to get a cake of soap and rub it on the leak. Not the whole cake obviously, just enough to cover the leak/hole.
#4 Re: Fuel Tank Has got a Tiny Hole
Sumith Posted on: 2010/7/2 6:09
HI DD
Yes that is ,
Fortunately i don't have any corrosion in my fuel tank
Thanks
Regards
sumith
