Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
what rim will 240/570R13's tyres fit on?
Matto1kUte
Posted on: 2010/8/8 12:59
hey guys i have just got hold of some 240/570R13 slicks. just wondering if there was a stock 13' rim that theese will fit on to to fit my 1000 ute? im using a slightly wider diff so im hoping it will clear.
#2
Re: what rim will 240/570R13's tyres fit on?
dattoman_1000
Posted on: 2010/8/8 14:11
10 or 11"
So no... there is no stock rim And unlikely they will fit without some tub work
#3
Posted on: 2010/8/8 16:36
Do you mean 240/50-R13?
A 240 width tire requires minimum 7" wheel width. Which is doable. Such a small diameter tire will fit a 1000 -- silviaspecr's 1000 has them 235/45R13 and 255/40-13 is available here.
#4
Shifty
Posted on: 2010/8/8 23:50
I think old mate means 245/70/13?
I'd recommend 8-9" as a minimum, but they should work on a 7" to 11" rim
#5
benny
Posted on: 2010/8/9 1:30
Most copetition slicks [well Dunlop at least] are rated with the dimensions of width, diameter and rim size. They dont refer to the side wall profle size [% figure]. running 240's on a 1000 is over kill IMO, I used to run 185/580/15 on my coupe and found them hard on the drive train as there is minimal tyre slip. If you run a locked center, I think a busted axle is just a matter of time. How many heat cycles have the tyres been through?
#6
Matto1kUte
Posted on: 2010/8/9 1:45
not sure but i know theres 60% tread left. i was going to use them for down at the drags when i put my 4agte in. i figured if im using a 1200 ute diff which is 30mm wider on each side the tyres will stick out more to give me a bit more clearence. does that sound ok? i was hoping there mite be a rim which would fit theese as my rx7 had 245's on 14's. if there is no rim what would it cost to get some widend
#7
benny
Posted on: 2010/8/9 2:20
They would hook up nice for the drags... Probably the easiest option is to have a pair of steel rims widened to suit. There are a few places in Sydney that do them...
#8
Matto1kUte
Posted on: 2010/8/9 4:37
yea in adelaide i rang one place. near $180 each. is that right? i was hoping some mags/rims would suit
#9
benny
Posted on: 2010/8/9 5:20
$180 is a bit rich, If it was for the pair then maybe... Its been years since I have had any rims widened so maaybe this is the going rate these days.
#10
Shifty
Posted on: 2010/8/9 5:30
funnily enough i priced a set in brisbane today... it was $180/rim also!!
that was to supply and fit 15x8 bands to an existing rim You can view topic.
