Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Another Air Filter Q - Too Small?
HamzaLH
Posted on: 2010/8/9 12:23
I had a thought this afternoon ...
Is this too small for the A12? http://www.knfilters.com/search/product.aspx?Prod=RC-2880 The flange is the right size, but the actual filter is rather small ... Hamza
#2
Re: Another Air Filter Q - Too Small?
1200rallycar
Posted on: 2010/8/9 13:03
sounds like a great size........... for the rocker cover breather...........
size doesnt actually matter, except it effect how often you need to clean/change it essentially air will suck through the path of least resistance, once that area of the filter blocks up a little it will suck from somewhere else. then after a while all areas are dirty and flow is restricted so a small air filter is ok if you clean regularily, in the case of this filter maybe once a fortnight or month? can you be bothered doing that?
#3
Shifty
Posted on: 2010/8/10 0:57
Sorry but that's not correct. Yes when a filter gets more dirty it will become more restrictive, but the smaller the filter the more restriction before you even start.
The same goes for any filter be it intake, crankcase breather, etc... People don't run bigger filters so that they don't have to clean them as often. They run bigger filters so that there is less restriction.
#4
HamzaLH
Posted on: 2010/8/10 1:09
I see both points of view ... But the way i look at it the stupid frypan has a TINY inlet compared to that filter, so it would be alot more restrictive ...
#5
spraycanmansam
Posted on: 2010/8/10 8:10
Sorry but that's not correct. Yes when a filter gets more dirty it will become more restrictive, but the smaller the filter the more restriction before you even start. The same goes for any filter be it intake, crankcase breather, etc... People don't run bigger filters so that they don't have to clean them as often. They run bigger filters so that there is less restriction. +1. Old school rule of thumb used to be that the air filter lid shouldn't be closer to the mouth of the carb than the bore of the carb. ie: if you have a 40mm Weber, the carb lib should be at *minimum* 40mm away from the mouth of the carb. It's all to do with pressure drops and airflow restriction. Short story: bigger is better when it comes to filtration. I can imagine the maintenance required to keep a filter that small from blocking up too quickly ..and when it starts to clog up the airflow rate would drop dramatically. Which is why I went with the biggest damn filter I could find! :P ![]()
#6
HamzaLH
Posted on: 2010/8/10 9:13
lol ... Very nice Sam ... But mt problem is fitting it under the bonnet ...
#7
LittleFireyOne
Posted on: 2010/8/12 4:40
I run a 9inch diameter by 3 inch high filter off something I sourced from wesfil. You should see what they do for the V8 supercars air filter, it's definatley big.
