#1 clutch for 60 series dogleg on 1400
cracka50 Posted on: 2010/8/24 12:26
Hi as the title says would this gearbox setup on my 1200 ute with an A14 engine
use a 1200 clutch?
thanks
adam
#2 Re: clutch for 60 series dogleg on 1400
ssskiwi Posted on: 2010/8/24 13:23
Just use the std clutch for that engine, think they are all pretty much the same anyway.
Maybe Vanettes have a heavy duty option??
#3 Re: clutch for 60 series dogleg on 1400
ddgonzal Posted on: 2010/8/25 4:48
The A12 and A14 clutches are the same size and bolt on
The factory A12 is a light action clutch, and factory A14 is heavy duty.
But most aftermarket clutches are the same A12, A14, A15. No difference.
Only the B210 5-speed clutch is different.
#4 Re: clutch for 60 series dogleg on 1400
cracka50 Posted on: 2010/8/25 8:17
excellent news
thankyou guys and gals,
also the gearbox makes no difference?
thanks again
#5 Re: clutch for 60 series dogleg on 1400
ddgonzal Posted on: 2010/8/25 21:10
All 60-series and 56-series RWD gearbox use the same clutch dimensions.
The gearbox makes a difference in other ways. Nissan did not use anything smaller than 60-series behind an A14. The 60-series floor shift versions are a nice smooth shifting gearbox.
