#1 H145 shims wanted
d_masa Posted on: 2010/8/31 8:25
Hello,
I'm looking for 2 pcs new planet gear shims 28426-18000, that I need for rebuilding a differential. Nissan no longer sells these. Should you happen to have spares, please make me an offer. I live in Finland, but these will fit in a letter so delivery is not an issue.
BR,
Matti
mvaaja at cc.hut.fi
#2 Re: H145 shims wanted
ddgonzal Posted on: 2010/9/1 3:26
I don't find that part number in the Datsun 1200 parts catalog.
Do you mean the differential side bearing shims?
* 38453-H1000 SHIM-ADJUST SIDE BEARING T=0.05
* 38454-H1000 SHIM-ADJUST SIDE BEARING T=0.07
* 38455-H1000 SHIM-ADJUST SIDE BEARING T=0.10
* 38456-H1000 SHIM-ADJUST SIDE BEARING T=0.20
* 38457-H1000 SHIM-ADJUST SIDE BEARING T=0.50
These are listed in the 2010 Nissan USA catalog, but cost $0.42 USD each.
Part #15 in this diagram:
#3 Re: H145 shims wanted
d_masa Posted on: 2010/9/1 8:00
Hi,
The parts that I am looking for are #11 in this picture. I have a pdf-version of a parts catalog, but I don't have it at hand to check what marketplace it is for. The #11 shims are the only ones in my diff that appear worn. There is slack between the carrier #7 and gears #8. Another option for me is to use the worn #11 shims and use thicker #9 shims. Could you please check if parts #9 and #11 are available in US?
Thank you,
Matti
#4 Re: H145 shims wanted
ddgonzal Posted on: 2010/9/2 3:53
#11 is not a shim, but a tension washer:
* 38426-18000 WASHER-THRUST PINION MATE $2.57 USD
#9 was available in 17 different thicknesses
* 38424-18000 Washer-thrust $1.68
* 38424-18001 Washer-thrust $1.78
* 38424-18002 Washer-thrust $1.92
The only way to tell if they are still available is to order them, and wait three weeks to get the answer.
P.S: The H145 differential part numbers are the same for all countries.
#5 Re: H145 shims wanted
d_masa Posted on: 2010/9/5 12:24
That is of course true, I had the first number in the part number wrong. I would be very grateful if you could ask your local Nissan dealer if these are available:
pcs Number Description
2 38426-18000 WASHER-THRUST PINION MATE
1 38424-18008 WASHER-THRUST SIDE GEAR
1 38424-18004 WASHER-THRUST SIDE GEAR
BR,
Matti
#6 Re: H145 shims wanted
ddgonzal Posted on: 2010/9/5 17:32
Hi Matti,
38424-18008 and 38424-18004 are not available.
However, these are listed in the Nissan 2010 USA catalog:
The only way to ask is to order them. Would you like me to order them for you? Tax is about $1, shipping to me and then to Finland will be about $12.
#7 Re: H145 shims wanted
ddgonzal Posted on: 2010/9/22 6:10
Hi Matti,
My Nissan dealer had Japan cancelled his order. No longer available.
Sorry. Hope you can find some New Old Stock ones.
dd
