#1 1200 Ute Coilovers.
bonney Posted on: 2010/9/25 12:13
Hey there, newbie question again! :)
I've been reading everything I can and I can't find a straight answer!
I want to put coilovers in the front of my '85 1200 ute, but I want to change as little things as possible, so I was wondering ... Can I get some 45mm OD KYB Gas Adjust inserts and weld on a coilover sleeve and put on the strut leg (Can it be removed and swapped, this has me stumped as well) and bob is basicly my uncle?
I would also like to fit bigger brakes in the future, so should I look at changing the strut types?
If someone can help me that would be great!
#2 Re: 1200 Ute Coilovers.
tommo73 Posted on: 2010/9/25 12:31
coil over bigger struts 200b,stanza,ect
#3 Re: 1200 Ute Coilovers.
ssskiwi Posted on: 2010/9/25 12:32
These are already done ready to go..
Wardy's coilovers with S13 brakes
#4 Re: 1200 Ute Coilovers.
bonney Posted on: 2010/9/25 12:59
I seen those for sale, don't really have cash on me atm haha.
wanted to maybe build them later on down the track.
#5 Re: 1200 Ute Coilovers.
ssskiwi Posted on: 2010/9/25 13:09
Fair enough, that's gives you the recipe anyway as to what you need to do to build a set.
#6 Re: 1200 Ute Coilovers.
bonney Posted on: 2010/9/26 0:18
Thanks for the reply guys!
But what is involved with shorting the strut?
#7 Re: 1200 Ute Coilovers.
ssskiwi Posted on: 2010/9/26 0:38
Couple of options I reckon:
1. cut them to length required and re-machine thread into strut tube.
2. cut section out and re-weld threaded setion to the top of the strut.
May be other ways but those prob the simplest..
I just cut the spring platforms off of mine with a 6" grinder and now need to get some inserts.
#8 Re: 1200 Ute Coilovers.
casey Posted on: 2010/9/26 1:04
iv just finnished my coilovers on my 120y struts. you dont need to shorten the strut i left it standard length replaced the shocks with some pedders inserts. and it nearly tucks my 155/80/12s
