Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Which thrust bearing carrier? (60a 5speed into 120y)
SunnyDaze
Posted on: 2010/11/7 1:00
I'm swapping my 56 series 4 speed gearbox with a 60 series 5 speed, which I believe is from a b310. The motor is the stock A12 on my 120y.
Should I use the B310 thrust bearing carrier (marked "B") or the one from my 120y?
#2
Re: Which thrust bearing carrier?
b310gx
Posted on: 2010/11/7 4:41
You need the thrust bearing housing from the 60A g/box, as the 60 series boxe need a longer housing. If you use the standard 56a housing the throwout bearing won't touch the pressure plate fingers & the clutch wont disengage.
#3
Weekend1000
Posted on: 2010/11/8 12:53
The one stamped "D" is best
#4
SunnyDaze
Posted on: 2010/11/9 10:27
So the carrier is determined by the choice of gearbox, as opposed to the motor? Or is it a combination?
#6
SunnyDaze
Posted on: 2011/1/9 8:38
I got the bearing carrier out of the 56 series 4 speed, and it turned out to be a few mm longer than the one supplied with my 60 series 5 speed (marked "B").
So should the use the slightly longer 56 series 4 speed one, the shorter 60 series 5 speed carrier (supposedly), or another carrier all together?
#7
Re: Which thrust bearing carrier? (60a 5speed into 120y)
SunnyDaze
Posted on: 2011/1/9 9:39
Here's my two bearing carriers. The 120y one is a few mm longer.
![]() http://datsun1200.com/modules/myalbum/photo.php?lid=22754
#8
Posted on: 2011/1/9 21:19
It depends on whether you use the engine plate or not. It doesn't depend on the year or the gearbox.
#9
Datsss
Posted on: 2011/1/9 22:13
Hiya, I had a similar prob when fitting up and a15 to a 4 speed and I hope I can help out a bit here.....It depends on what flywheel you are using as the a15 flywheel is thicker. You,ve prob got a standard a12 flywheel so use all the 4 speed stuff.
I fitted an a12 flywheel to my a15 so I could fit it to a 4 speed.....
#10
SunnyDaze
Posted on: 2011/1/9 22:25
The only thing that has changed in my setup is the gearbox.
So it sounds like I just use the carrier I was using before (The stock 120y one). Thanks all. You can view topic.
