Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
CA18DE with Side Draft Carburetors
bezman
Posted on: 2011/1/12 6:06
HI there I know this has been discussed before, but most threads were old and the threads were never really updated with working results.
I am looking to build a high comp NA CA18DE motor, why? because i have built 400whp CA18/CA19DET's, we no longer have a race track in my country, so most of my driving in on windy roads and nowhere to really accelerate past 180kmph.. and i want do experiment with Carbs and NA tuning etc.. I have a CA18 registered in my car and changing engine numbers in my country is a pain in the ass to say the least.. So i am going to buy an extra head and port, polish and build the valve-train and carb setup, sort out the distributor issue and then buy some high comp custom pistons and do quick rebuild/refresh with the new pistons and head/carbs/distributor setup.. (not selling any of my turbo bits, so if it sucks, i can swap it all back easily - plus my turbo seals are gone and my manifold is leaking - so i need to replace these bits anyway sometimes very soon) I have seen that people that have done this or started the swap have used a distributor in place of the Crank Angle Sensor, my questions is which one? Subaru? Mitsubishi? Nissan?? What is involved in swapping in a distributor instead of the Crank Angle Sensor? do you simply remove the rotor shaft that goes into the cam shaft from the CA18 Crank angle sensor and fit/weld it onto a distributor? In that case most any distributor should work? I am also guessing that this will allow you to eliminate the AFM? and you would jsut use a MSD and coil for spark tuning?? I didnt want to bump other people threads that were from 2006, so i started this one to hopefully get some clear answers.. I have found a set of 4A-GE 20v Throttle Bodies for dirt cheap, but dont know of a cheap/easy way of eliminating the AFM without buying a haltech etc, and i've been down that road already and would get some giggles out of tuning with no ECU.. Ideas, comments and opiniosn welcomed, but i am going to do this :) I always steer at this photo and wonder how he is running it with the CAS and no Air Flow Meter??
#2
Re: CA18DE with Side Draft Carburetors
tommo73
Posted on: 2011/1/12 6:37
cas fires stand alone spark only ecu
maf only needed for fuel injection spark can run of cas(cam angle senser) or crank trigger cas(crank angle senser)
#3
A14force
Posted on: 2011/1/12 7:07
If you can lay your hands on one, you'd be better off to try and find a 4 port head. It'll make you sidedraft to head manifold less complex.
#4
TUF-110
Posted on: 2011/1/12 7:32
Use a mitsubishi sigma dizzy, off a 2.6 astron motor these dizzys run retarted opposed to advanced so the opposite of most dizzys, so you get a gear made up for the dizzy to match the exhaust cam gear and run it off that with a bracket, eliminates any form of computer, just fire it up!
#5
bezman
Posted on: 2011/1/12 14:15
thanks guys,
@tommo73 - thanks, was thinking of getting a AEM or similar ignition control unit.. just didnt know how the AMF would come into play @A14force - i have been trying since 2002 when i first got into ca's to source a 4 port CA head locally, it's seems we only got JDM 8 ports.. @TUF-110 - I think I may go this route, need to find the dizzy and have a look at it and the CAS thanks guys and keep the advice coming :)
#6
clyons8
Posted on: 2011/1/12 22:18
Have you managed to find a Twin Sidedraft Carburetor manifold? Very interested to hear (literally hear) how the engine goes. Good luck with it all, keep the updates coming.
#7
bezman
Posted on: 2011/1/12 23:59
iam using the 8 port head with the bottom section of the stock manifold with the butterflies, i will be taking the butterflies out and seal the holes up. Then I will get an aluminum flange cut to mate to the CA18 lower inlet flange and tap it with the bolts for the webber to bolt to.. I'll weld a bracket for the throttle and other bits to the lower manifold too..
![]() this is a photo from the sites photo album... my main concern now is space to fit a distributor where the CAS is as i only have about 4" between the cover and radiator, finding a ignition only management system for reasonable costs seems to be difficult so using the CAS seems out of it.. You can view topic.
