#1 EOI alloy drop tank for 1200 ute
ZigZag Posted on: 2011/1/30 2:11
thinking of selling my drop tank, holds roughly 40L, paid around $350, just seeing if there is any interest.
jpg  !Br4-3kgCGk~$(KGrHqEOKkEEvNsEoVIIBL1mlhEHEQ~~_12.jpg (18.13 KB)
10257_4d44c8caae1cc.jpg 500X375 px
#2 Re: EOI alloy drop tank for 1200 ute
aidaniel Posted on: 2011/1/30 2:38
id be pretty keen ... is it baffled? and where did you set up or plan to setup the filler?
#3 Re: EOI alloy drop tank for 1200 ute
ZigZag Posted on: 2011/1/30 2:54
not sure bout the baffeling bought it off a guy in brissy that was running it in his ute and had compliance.
filler opening is on the drivers side so you would just have to extend your original filler hose.
#4 Re: EOI alloy drop tank for 1200 ute
ZigZag Posted on: 2011/1/30 2:56
another pic
jpg  !Br4-rqwBWk~$(KGrHqYOKkIEvOnGj)RHBL1mj6mlZw~~_12.jpg (17.95 KB)
10257_4d44d370d7497.jpg 500X375 px
#5 Re: EOI alloy drop tank for 1200 ute
1200rallycar Posted on: 2011/1/30 7:09
that looks a hell of a lot like it is made for a coupe???
could be interested if so
#6 Re: EOI alloy drop tank for 1200 ute
ZigZag Posted on: 2011/1/30 7:12
if the underside is similar to a ute then it will work as it already has the 4 mounting tabs, fits nicely where the spare wheel carrier is on utes
#7 Re: EOI alloy drop tank for 1200 ute
1200rallycar Posted on: 2011/1/30 7:17
ok, cause the ute tank is short and fat. the coupe is very similar shape to this, if this was made for a ute it would be a small miracle that the dimensions line up
#8 Re: EOI alloy drop tank for 1200 ute
ZigZag Posted on: 2011/1/30 8:29
it goes where the spare wheel carrier goes, behind the diff, fits snug up there, does not mount where the original tank mounts
#9 Re: EOI alloy drop tank for 1200 ute
ZigZag Posted on: 2011/2/1 9:36
will swap for 2 x R31 fuel tanks
