#1 Will 16 x 7 + 15 offset Fit standard 1200 suspension??
datsphat Posted on: 2011/3/1 5:18
was looking at a set of wheels and was wondering if they would fit stock suspension setup.
16x7+15
if they wont fit what would need to be done to make them fit?
Cheers..
#2 Re: Will 16 x 7 + 15 offset Fit standard 1200 suspension??
datsphat Posted on: 2011/3/5 6:23
bump.
#3 Re: Will 16 x 7 + 15 offset Fit standard 1200 suspension??
ddgonzal Posted on: 2011/3/5 6:51
no, but with some wheel spacers they will fit
#4 Re: Will 16 x 7 + 15 offset Fit standard 1200 suspension??
datsphat Posted on: 2011/3/5 8:49
Thank you its much appreciated.
#5 Re: Will 16 x 7 + 15 offset Fit standard 1200 suspension??
ddgonzal Posted on: 2011/3/5 18:46
See Wheels for details.
Regardless of the diameter, maximum width is 7" to fit under the stock guards -- but it only fits with offsets of about +10 to -10.
8" wide or even 10" wide will fit if you let them stick out from the side of the car (fit stretch tires and/or overfender flares).
