#1 FS: NEW 76mm JE Forged race pistons & USED 74mm Venolia
pjz Posted on: 2011/3/4 1:53
In the shop I found the following Datsun 1200/A-series race pistons:
(6) NEW 76mm J&E forged, wedge dome A-15 race pistons. $USD 350 + shipping. NOTE 1: Only have NEW rings, pins and clips for ONE PISTON. You will have to source the others. Easy, as they are common rings. NOTE 2: These were made by J&E with a 0.300" wedge dome, then 5 of the 6 had the dome machined down. You need to machine the 6th to match. NOTE 3: These are made with a shorter compression height for the A-15. They can also be used in the other A-series engines.
(7) USED 74mm Venolia, forged wedge dome A-13/A-14 race pistons, with pins, used rings and used teflon buttons. $USD 100 + shipping.
Peter
Email is best. PeterZekert (at) Juno.com
