#1 Light switch part #?
edp Posted on: 2011/5/18 6:58
which of these is the correct part number for the coupe headlight switch?
Straight fro the Wiki....
Thx.!
Light Switch
25160-H1010 COMP-SWITCH LIGHTING WITH FOG SWI [OPTION, -0172]
25160-H4600 COMP-SWITCH LIGHTING 0172-
B5160-B6800 COMP-SWITCH LIGHTING [new part number]
replaced 25160-H1001 COMP-SWITCH LIGHTING
25165-H1000 KNOB-LIGHTING SWITCH -0172
25165-H4600 KNOB-LIGHTING SWITCH 0172-
25165-T3000 KNOB-LIGHTING SWITCH [new part number]
#2 Re: Light switch part #?
ddgonzal Posted on: 2011/5/18 7:29
Well it's none of the KNOB part numbers.
So that leaves:
* 25160-H1010 COMP-SWITCH LIGHTING WITH FOG SWI [OPTION, -0172]
* 25160-H4600 COMP-SWITCH LIGHTING 0172-
* B5160-B6800 COMP-SWITCH LIGHTING
If you have the optional switch with Fog Lamp, get 25160-H1010
Or if your 1200 was built after January 1972 (per the MVSS label on the door pillar) get 25160-H4600
Before Jan 1972 get B5160-B6800
If you have changed wiring harnesses, who can tell? Better to verify your wiring to ensure that the switch is the problem.
In any case I would guess that any of these will work, as will switches from Datsun 620 pickup. They may all be NLA, but you never know until you ask your dealer.
#3 Re: Light switch part #?
edp Posted on: 2011/5/18 16:23
I didn't realize any of those were knob #'s, it doesn't really spell it out.
I need to bypass the switch to see if its the problem which I've not done yet but thought I'd check & see if a new one was available.
Thx.
