Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
CA18DET turbo oil feed help.
RSR100
Posted on: 2011/12/28 14:15
hi guys
I'm starting to work out what i need to make up the oil lines to the turbo.im running a garrett turbo which has two tags on it "GT3071R" and "GT2835-56T".What i was planning on doing was removing the standard oil feed block from the motor and getting a fitting from the block to -4 AN then run to the turbo inlet with braid. What i cant find is a fitting to suit the thread in the engine block once i've removed the standard elbow. ive tried 1/8" NPT which is tappered thread, didnt work. Can someone advise me if its a metric or imperial thread? i was thinking 1/8 BSP or M10 x 1mm?? Another thing im not to sure about is that the original elbow has a restrictor in it. Because im removing that fitting do i still have to run a restrictor at the turbo inlet? turbo is ball bearing. Last one is ive purchased a turbo inlet fitting which is a male inverted flare 7/16" -24 short. it threads well into the turbo inlet but seem to reach the seat in the turbo after just 2 - 2.5 turns. it seem to be sealing good but the fitting seems to stick out a fair bit? has anyone encounted this before? different fitting or leave it as is? any advive is greatly appreciate guys cheers Rob
#2
Re: CA18DET turbo oil feed help.
oda70
Posted on: 2011/12/29 9:34
speed flow. pretty sure thats the one
1/8” BSPT -4. 381-04 could ask this guy, helped me out before with the ca lines http://www.midnightmods.com.au/zen-ca ... &cPath=68&products_id=191 buying a kit some times works out better
#3
supafatto
Posted on: 2011/12/29 10:27
1/8bsp to -??an what Eva size u want as long as banjo bolt is the right flow
#4
dattoman_1000
Posted on: 2011/12/29 12:22
The threads on the turbo will be metric
The thread off the oil pump outlet for feed is probably BSP... which I think is 28 threads per inch... and NPT is 27 Usually they pretty much interchange The catalogues I have say the thread for the oil pressure switch on a CA18 in an EXA is 1/8 gas You'd think Nissan would use metric threads... but not always the case Though I have no CA experience so just going on L and A series info here You can view topic.
