#1 Castor rod washes??
steve1991 Posted on: 2012/1/6 11:32
Anyone have or know of where I can get the castor rod washes that sorround the bushes?? It's for a 1200 ute.
#2 Re: Castor rod washes??
DatsAndy Posted on: 2012/1/6 12:07
Guess you need 4 i can help with as many as you like. Recommend using a flat washer between the nut and outer bush washer. As you can see the castor should have one built in to stop them tearing through (Never seen it but i guess thats why its there)
#3 Re: Castor rod washes??
steve1991 Posted on: 2012/1/6 12:33
I only need one of the inner washers plz. The one I pulled off was completely cracked in half and mangled.
#4 Re: Castor rod washes??
steve1991 Posted on: 2012/1/7 22:48
