#1 Early or late a12?
zakdat Posted on: 2012/6/18 13:19
Just wondering which a12 this is, the distributor is behind the engine mount, alternator is on the left.
#2 Re: Early or late a12?
1200rallycar Posted on: 2012/6/18 13:26
late
early has front dizzie and alt under exhaust
#3 Re: Early or late a12?
zakdat Posted on: 2012/6/18 13:30
ahhh, so if i buy a buy an early block, it wont bolt up?
#4 Re: Early or late a12?
davem69 Posted on: 2012/6/18 14:27
yes it will u just have to use the right engine mounts
#5 Re: Early or late a12?
darrenwilson Posted on: 2012/6/18 17:07
Use engine mounts for early a12 on early 1200 crossmember.
#6 Re: Early or late a12?
ddgonzal Posted on: 2012/6/18 20:01
You can bolt new A12 into old 1200 or old A12 into newer vehicle with slight fabrication. See A-series Engine Swaps.
#7 Re: Early or late a12?
Stock1200Ute1 Posted on: 2012/6/18 23:48
Dead set man go late, there is more bits around. I blew my early a12 up and starting building a late model a12 started with block and everything was different. I would highly recommend starting with a long motor!!
