#1 EOI.thinking of building front strut setups.way cheaper then elsewere
Datrotor Posted on: 2012/7/11 3:42
Wondering if any1 is intrested in buying front strut set ups? Same offered from maddat but without that price tag.will use stanza struts (shortened to suit you) Pedders inserts,new Pedders strut tops and custom coilover kit.i will be building these myself so anythings changeable.thanks
#2 Re: EOI.thinking of building front strut setups.way cheaper then elsewere
StinkyRooster Posted on: 2012/7/11 3:46
ballpark price? Coz I might be....
#3 Re: EOI.thinking of building front strut setups.way cheaper then elsewere
supafatto Posted on: 2012/7/11 5:33
:) need a supplier?
#4 Re: EOI.thinking of building front strut setups.way cheaper then elsewere
Datrotor Posted on: 2012/7/11 7:00
Can also do complete front ends, including brakes, hubs, control arms.everything you need all rebuilt and brand new Pedders bushings
#5 Re: EOI.thinking of building front strut setups.way cheaper then elsewere
mcdat Posted on: 2012/7/11 7:18
Hi datrotor what sort off coin we looking at for a complete front end,what calipers will u be using,rotor size.Ajustable control arms etc.
#6 Re: EOI.thinking of building front strut setups.way cheaper then elsewere
cracka50 Posted on: 2012/7/11 8:12
Id like to see some 45mm strut love. everyone always does stuff for stanza struts.
#7 Re: EOI.thinking of building front strut setups.way cheaper then elsewere
wards Posted on: 2012/7/11 8:24
Will you be supplying a engineers certificate with them and do you have a valid product liability insurance policy and do you hold the appropriate welding qualifications to modify suspension components? This is why the maddat ones are the price they are, do you realize that if your modified component fails and is the cause of a crash/fatality you can be held liable and be sued for everything you own? Again this is why things cost what they do . Sorry to put a downer on your business venture but you must think of all the above if you are going to charge money for your parts
#8 Re: EOI.thinking of building front strut setups.way cheaper then elsewere
Datrotor Posted on: 2012/7/11 8:44
I am qualified for welding who ever buys them can pick weather they want to go get it engineered or not.they are all up to standeds so everything's all good :) they charge what they do cause they want to not because they have to.thanks :)
#9 Re: EOI.thinking of building front strut setups.way cheaper then elsewere
ddgonzal Posted on: 2012/7/11 9:00
Do Australians sue over everything? Guys here do it all the time I never heard of them being sued. Although Companies do get sued...
#10 Re: EOI.thinking of building front strut setups.way cheaper then elsewere
cracka50 Posted on: 2012/7/11 9:24
Not so much, workers compensation is the big one here, i think anyways.
