Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
front tires ute 1200
alton1200
Posted on: 2012/7/21 19:17
i have a ute stock can 14"x5.5 rim fit and what size of tires
#2
Re: front tires ute 1200
darrenwilson
Posted on: 2012/7/21 19:36
Yeah They will fit,195/50/14 wider Tires handle better.
#4
Posted on: 2012/7/21 21:33
5.5 inch wide wheels will fit in most offsets
The tyres that will fit -- see a tire chart from a tire manufacturer. For example: BF Goodrich T/A 195 or 205 tyre: 5.5-7" rim width BUT, will a 195-width tyre fit? See Offset, where it says you'll need to roll the guard and use a 26 to 38 offset wheel (not sure how accurate the chart is). If you put overfender flares or let it stick of the body side, you can go with less offset or wider tyres.
#5
Posted on: 2012/7/22 0:59
If its stock 195 wide will increase rolling resistance, increasing fuel use and decrease acceleration responsiveness slightly.
If its stock, put 175 60 14 on them. Handles better than stock and cheap to get even 2ND hand.as.net Toyota yarris echos Honda jazz.size cars use them You can view topic.
