#1 How to take out axels on a bluebird diff?
DATUTE1 Posted on: 2012/10/1 9:33
Anyone tried to take out the axels on a bluebird diff?
Tried banging, pulling and even heating. Is there a trick? Would appreciate any tips.
#2 Re: How to take out axels on a bluebird diff?
1200rallycar Posted on: 2012/10/1 9:36
did it last week
take caliper off, undo 4 bolts, undo handbrake cable and it should pull out
put the drum/disc back on the wheel studs backwards then wind each of the wheel nuts on a couple of turns, then use the drum as a slide hammer by sliding it back and forward on the wheel studs
#3 Re: How to take out axels on a bluebird diff?
DATUTE1 Posted on: 2012/10/1 12:36
Thanks mate. I'll give the reverse disc a try. Are the normally hard to get out?
#4 Re: How to take out axels on a bluebird diff?
1200rallycar Posted on: 2012/10/1 12:44
i've always done it that way, takes about 3 or 4 decent slides and it pops out,
make sure the car is well supported so it doesn't fall (especially if using cheap axle stands)
#5 Re: How to take out axels on a bluebird diff?
DATUTE1 Posted on: 2012/10/2 13:09
Will definitely give that a go. No problem with the car being supported, the diff was taken out!
#6 Re: How to take out axels on a bluebird diff?
PIGDOG Posted on: 2012/10/3 1:10
or do the same with a wheel
just dont hit the disc with a hammer....they dont like that
#7 Re: How to take out axels on a bluebird diff?
DATUTE1 Posted on: 2012/10/6 9:06
Thanks Michael or Claire (whoever wrote the post). I owe you a beer If you ever come to Canberra.
Came out in two slides! So easy when you know how.
