#1 Will these tiny holes be a matter later ?
Sumith Posted on: 2012/11/23 6:16
Hi Guys
I have Tiny holes as per the pics in the middle of the head like this, right at the moment those are not leaking coolant or oil to the surface ,but some are little deeper about 4/1 inch will these be a problem later ?
do i need to fill them and reface the head ?
thanks
regards
sumith
jpg  1.jpg (47.73 KB)
10994_50af149072f71.jpg 640X480 px
jpg  2.jpg (47.70 KB)
10994_50af14a5f0a89.jpg 640X480 px
jpg  3.jpg (64.34 KB)
10994_50af14b051172.jpg 640X480 px
#2 Re: Will these tiny holes be a matter later ?
ddgonzal Posted on: 2012/11/23 7:09
up to 5 mm deep?
#3 Re: Will these tiny holes be a matter later ?
1200rallycar Posted on: 2012/11/23 7:13
it's round port a12.... just get a new one... that does not look good at all
it looks like it could still have a fair bit skimmed off it, but still it's a cheap head so i would just replace
#4 Re: Will these tiny holes be a matter later ?
Sumith Posted on: 2012/11/23 7:40
Hi Guys
I didn't measure them but they are little deeper, so far this was running without any issue , but i was just thinking to fill it and reface it .
Buying a new head is very expensive here is is not affordable right now
thanks
regards
sumith
#5 Re: Will these tiny holes be a matter later ?
ddgonzal Posted on: 2012/11/23 7:47
If it is 1/4" (5 mm) deep, i wouldn't trust that cylinder head. The casting is thinner than that in many places.
I've never seen a head with that problem.
#6 Re: Will these tiny holes be a matter later ?
PITBULL Posted on: 2012/11/24 20:04
Have them milled out by carefully measuring their depth respective to the water/oil channels and have them welded up and re-surfaced. If you have an engineering connection. Should be cheaper than another head if they are so expensive. but its bound to give in soon.
#7 Re: Will these tiny holes be a matter later ?
Rallytwit Posted on: 2012/11/24 20:47
Once upon a time we have used a 2 part epoxy to fill this type of damage, simply wiped off the excess.....far far from ideal but it did hold together until the car was done in by an SUV 2 years later.
Tom
#8 Re: Will these tiny holes be a matter later ?
Muckenrefarkabl Posted on: 2012/11/25 0:34
the holes are way to close to the sealing ring of the head gasket, honestly i wouldnt try reuse it
#9 Re: Will these tiny holes be a matter later ?
Sumith Posted on: 2012/11/30 5:25
Hi Guys
Got the head filled and refaced and made few stud which were in bad condition and installed a new plug hole adapter to cylinder no 2,hopefully it has to run better since it was running earlier also,
thanks
regards
sumith
jpg  1.jpg (61.23 KB)
10994_50b8438cc3ceb.jpg 640X480 px
jpg  2.jpg (59.97 KB)
10994_50b84397b98e6.jpg 640X480 px
jpg  3.jpg (61.23 KB)
10994_50b843a6d3db9.jpg 640X480 px
#10 Re: Will these tiny holes be a matter later ?
dattodude Posted on: 2012/11/30 9:49
Good to hear. I have thought about this a couple of times lately. It will be good to hear that your car is on the road.
