Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
which struts will fit s13 rotors?
datsen_14
Posted on: 2012/11/25 8:47
hi i was wondering if there is a era of 120y/coupe disc brake struts i should be getting or are they all the same?
and will this combo change track?
#2
Re: which struts will fit s13 rotors?
Posted on: 2012/11/25 10:00
The pbr style struts I think. And, you need the kev Rowley adaptors too.
Won't increase track as much as stanza conversion
#3
datsen_14
Posted on: 2012/11/25 10:12
is there a way i can tell if they are pbr struts? and are the adaptors for the caliper mounts?
#4
supafatto
Posted on: 2012/11/25 10:14
Also depends on ball joints use bj176 if you want smattering track
#6
datsen_14
Posted on: 2012/11/25 10:30
i would rather less track if i can. my rims sit outside the guards already.
so what do i need to look for in struts?? i can engineer a caliper mount
#8
ANGE
Posted on: 2012/11/25 10:39
you can use 1200 disc struts or 120y disc struts. the later model 120y struts (that came with pbr calipers) are the better
ones as they have a larger stub axle. your track will increase by approx 7mm per side (the thickness of the disc mounting face) because the rotors slide over the hubs. you will need custom caliper bracket and to machine your hubs to accept the s13 rotor
#9
datsen_14
Posted on: 2012/11/25 11:03
thanks fellas. does anyone have any to get rid of?
