#1 Question about Break Master Clearance?
CrazyHawaiian Posted on: 2012/12/2 16:58
I'm going to run Dual weber dcoe's and noticed the clearance with the break master,what to do, I see some people eliminate the fluid res. and ad these L connectors???remote Res?
Ware do I get those ???
#2 Re: Question about Break Master Clearance?
da71cp Posted on: 2012/12/2 18:15
If I remember, wilwood sells a base adapter and remote reservoir with their clutch master kit. Bought one a while ago and kept the adapter for something in the future. Anyway, there are several different cars that use the same diameter base on the clutch master as the 1200 brake master. If you're savy, go to the junkyard and check the mitsubishi front wheel drives and on the clutch master you'll find the bottom adapter you're looking for. The remote reservoir they use might work as well for your brake system.
#3 Re: Question about Break Master Clearance?
CrazyHawaiian Posted on: 2012/12/2 18:27
I figured it out !
Remote setup.
