Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Ca18 inlet manifold question. Where this pipe goes?
bailz
Posted on: 2013/1/22 12:20
Simply. 90degree fitting at the back of the ca18det manifold. When I say the back I mean the square plate on the log part of the manifold. Where does it go to? I am assuming something I don't need to run it in my 1200?
#2
Re: Ca18 inlet manifold question. Where this pipe goes?
dattodude
Posted on: 2013/1/22 13:16
BIg one is for booster.
#3
bailz
Posted on: 2013/1/22 13:26
The one with the 90 deg fitting on it? the big one with a one way valve thing has a pipe which goes to the top of the rocker cover :) I might use it for the boost actually l :) cheers for that :)
#5
bailz
Posted on: 2013/1/23 6:04
The one that is snapped off in that pic I was told goes to the booster?
#6
Posted on: 2013/1/23 7:26
On the JDM S13 it goes to the vacuum tank (not the brake booster).
#7
bailz
Posted on: 2013/1/23 12:58
I need a vacuum tank?
#8
Posted on: 2013/1/23 20:54
No you don't need a vacuum tank. But the S13 used one.
