#1 L20B pollution control
crumb Posted on: 2013/3/6 12:06
#2 Re: L20B pollution control
Posted on: 2013/3/6 20:32
Came out in 1974 til 1985
wiki
Not sure if that's accurate for aus. But the earlier the better
#3 Re: L20B pollution control
Posted on: 2013/3/6 20:44
In aus 1977 200b was earliest unfortunately with l20b
#4 Re: L20B pollution control
crumb Posted on: 2013/3/6 23:56
#5 Re: L20B pollution control
lamb_daiquiri Posted on: 2013/3/7 3:34
Can you fit the L20B crank/ rods/ pistons in an L18 block? Maybe a way around it? I dunno personally.
#6 Re: L20B pollution control
Posted on: 2013/3/7 3:53
Block is 20mm taller for l20b.
Pcv shouldn't be too hard
#7 Re: L20B pollution control
lamb_daiquiri Posted on: 2013/3/7 5:06
There you go.
#8 Re: L20B pollution control
crumb Posted on: 2013/3/7 5:07
Good idea but i really want to keep the block i have as is has had a bit of work done to it, I should have most of the bit and pieces to fit. Just really time poor at the moment and looking for the easy option if it existed.
Wont be hard but just finding time is.
#9 Re: L20B pollution control
Posted on: 2013/3/7 6:32
Read this
But pretty much post July 1976 is bad. You want pre 76 which is not possible so technically you need pcv, carbon canister and all the yucky pollution stuff. Knew there was another reason for straight Lpg
