#1 R31 Struts
Jac0001 Posted on: 2013/7/1 13:06
Hey guys, I have a pair of r31 front struts laying around and im looking at putting coilovers on and putting them in my ute just wondering what i need to do his conversion. i know i need stanza control arms, steering arms, ball joints and i need a spacer machined up what else do i need?
cheers Jac
#2 Re: R31 Struts
Jac0001 Posted on: 2013/7/2 12:18
anyone?
#3 Re: R31 Struts
PIGDOG Posted on: 2013/7/2 12:30
what year is your ute? if its after about 75-76 it will already have the correct control arms and castor rods, then you will just need the stanza balljoints and steering arms, possibly longer tierods and the location spacer for the steering arm.
Will need coilovers as the standard r31 springs are too large, but you already have that planned.
Then you need to sort out brakes, which may require a slightly larger master cylinder
#4 Re: R31 Struts
Jac0001 Posted on: 2013/7/2 12:48
ok thanks mate, its an 80 so i should just need ball joints and steering arms and the spacer right? and yep doing coilovers.
what should i get the master cylinder from?
cheers Jac
