Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Car stalls approaching lights
darrenwilson
Posted on: 2013/7/22 14:13
i have a weber 32/36 on my a15 and it stalls coming to the traffic lights.i don't have a clue on what might be the problem.when i give the check valve a tap from the top of the cabby it idles back perfectly when i run hard again its stalls again at the traffic lights
#2
Re: Car stalls approaching lights
Posted on: 2013/7/23 1:02
Stalling coming to the traffic lights is usually caused by a lean mixture.
* Float level not set correctly or * A/F mixture not adjusted or * Air leak (vacuum leak) This suggests a sticking fuel inlet valve: "when i give the check valve a tap from the top of the cabby it idles back perfectly"
#3
darrenwilson
Posted on: 2013/7/23 20:58
Does the weber have a idle speed to set or just the A/F mixture?
#4
Posted on: 2013/7/23 23:40
Weber 32/36 is a conventional carburetor and so has both the usual Idle Speed and Idle Mixture screws. Set them both. If the idle is too low, it can cause stalling problems. If the mixture is too lean, same result.
Set it to 750 rpm and best lean idle. You can view topic.
