#1 Need Lowering Block Width for 120Y
guyster Posted on: 2013/11/20 17:16
Does anyone know the width of the rear axle of a 120Y? I don't have access to the car right now and want to order blocks. Thanks!
#2 Re: Need Lowering Block Width for 120Y
ddgonzal Posted on: 2013/11/20 19:15
All B210s have leaf springs the same width as the 1200 (50 mm). So width of blocks is the same. But the pin and hole sizes are different (some blocks have enough meat to hog out the hole to correct size/location).
B210 uses isoclamp to mount the leaf packs, so slightly wider blocks will fit too
