Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
FS5W71B
rallymaster
Posted on: 2014/1/27 23:04
Hi guys
I have an opportunity to get my hands on 5 5speed FS5W71B Just wondering will they work on an a series engine. if not there is no point in me buying them.... Thanks
#2
Re: FS5W71B
Posted on: 2014/1/27 23:30
Yes, it will fit if you use an adapter plate, some machining and fabrication.
The 71-series can handle 200 lb ft torque, so is a good choice for a high-boost engine.
#4
Re: FS5W71B
Posted on: 2014/1/28 10:33
Unless you need an extremely overkill gearbox, it is much better to find a good A-series transmission. See 5-speeds.
#5
Re: FS5W71B
Posted on: 2014/1/29 1:55
Perhaps the most popular way to make an L-series gearbox fit an A-series engine is is to cut the front case and weld on a bit of case from a common A12 4-speed.
For example, Silva S15 6-Speed gearbox modified for use with A12 engine See http://datsun1200.com/modules/mediawi ... ission_Swaps#Cut_.26_Shut You can view topic.
