Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
My B310 died suddenly, No Ignition
Sumith
Posted on: 2014/3/3 3:10
hi Guys
My B310 died suddenly , it lost its power did not pull at all,and also the same time i had a bad exhaust misfire it started but could not reach higher rpm, initially it was like a problem of fuel system ,but later it did not start at all, so checked it and found no ignition, checked all the wires and they were ok,rotor had black carbon marks on it so i cleaned it and i pulled the ignition coil wire which goes to the middle of the distributor cap which is coming from ignition coil secondary circuit(middle Wire) i tried the circuit by manually using a screw driver it had a nice spark at the end of the ignition coil wire(secondary Wire) , but when i turn the engine with the starter it doesn't give spark to the wire so i checked the contact point gap and also contact point is opening and closing accordingly, what could be this strange problem ? have anyone come across slimier situation ? thanks regards sumith
#2
Re: My B310 died suddenly, No Ignition
SquareNacho
Posted on: 2014/3/3 3:26
Just a stupid idea but you could try to charge your battery and see if that does anything
#3
72datto
Posted on: 2014/3/3 4:04
Maybe try the condenser??? Mine failed the other day and it was acting like a fuel problem just wouldn't rev and missing.
#4
Sumith
Posted on: 2014/3/3 4:25
Hi 72datto
I Tried changing too, If it is bad i won't get good spark while doing it manually through a screw driver, i am just now thing on my ignition switch working weird, while cranking the starter , just like voltage drop on start position of the key ? thanks regards sumith
#5
Sumith
Posted on: 2014/3/8 12:43
Hi Guys
Sorted out it as i thought it is the Ignition Switch , It Drops the Current on Start Position, so car won't get voltage to ignition while cranking thanks regards sumith You can view topic.
