Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
accelerator cable 120y to holley
anths
Posted on: 2014/3/20 3:45
G'day guys,
does anyone know who supplies new accelerator cables to suit the 350 holley as my original is not long enough to do the job and i need to come around the front of the engine not firewall side or someone explain how its done cheers
#2
Re: accelerator cable 120y to holley
Posted on: 2014/3/20 4:41
Maybe 180B/610 is longer, or 200B/810?
#3
1200rallycar
Posted on: 2014/3/20 4:57
i would go to the wrecker and find something i could make work from another car
#4
supafatto
Posted on: 2014/3/20 6:41
I modified a bonnet cable for mine or you could use push bike brake cable a braise the ends on
#5
anths
Posted on: 2014/3/20 7:13
I was wanting to try and retain the factory fittings in the fire wall,
But yes i could go to the wreckers and grab a E series cable and peddal which might be the easy solution as there easy to source parts Edit : ok have figured out a way cheers guys i will see if this works
#6
crumb
Posted on: 2014/3/20 18:21
Just in case it doesn't work the way you want it to, there is i guy name joe out in yarrambat that does car cables. i took my accelerator cable there when i put the EFI on as it needed to be twice as long, Just gave him the lengths i wanted and the old cable and two hours later it was done. cost me $60 but there was no trying to find what worked.
Auto Cables Joe pace 94361260.
#7
Posted on: 2014/3/20 21:04
Speedscreen in flemington too but usually overnight
