#1 Gear Reduction Starter Fitment to A12
OGREInc Posted on: 2014/5/6 22:19
Does the Datsun 1200 Galaxy of Stars have any updated input on fitting a later model B210 / B310 gear reduction starter motor to an A12 engine?
The tech wiki sort of leaves us hanging whether it is doable or not.
I feel that my A12 racing engine with nearly 13:1 compression will need a bit more cranking "oomph" when I go to light it up, both cold & hot.
Thanks!
#2 Re: Gear Reduction Starter Fitment to A12
ddgonzal Posted on: 2014/5/6 22:31
Sure it'll fit the A12 engine. But it won't fit in the 1200 car. It doesn't even fit 1974-1976 B210 Maybe if you notch the engine mounts?
#3 Re: Gear Reduction Starter Fitment to A12
benny Posted on: 2014/5/7 1:27
I did what DD suggested to fit mine into my 1200. Notch the engine mount to provide the clearance
#4 Re: Gear Reduction Starter Fitment to A12
OGREInc Posted on: 2014/5/8 4:49
Benny,DD:
Thanks for the info!
Sounds like the reduction gear starter is longer than the OEM A12 starter?
How deep of a notch in the engine mount is required? (any issues with structural integrity of the engine mount?)
Bolt pattern and flywheel engagement gear are the same?
Again, thanks!
#5 Re: Gear Reduction Starter Fitment to A12
ddgonzal Posted on: 2014/5/8 5:51
Longer?
Just a different shape
Style 1
Style 2
