#1 draw through turbo carbon seals?
a12datto120y Posted on: 2014/9/24 11:59
hi i am considering doing a draw through turbo setup using a wrx td04l and was wandering if everyone who has a draw through setup has used carbon seals.
if not did the turbo burn oil at high vacuum?
thanks!
#2 Re: draw through turbo carbon seals?
dattoboy_nz Posted on: 2014/9/24 12:54
I ran a primary turbo off a twin turbo subaru that wasn't carbon seal. The seals let go after about a month of driving.
I then went to a carbon sealed Garret T2 off a E15 Pulsar (i think they were carbon sealed from factory but can't quite remember)
#3 Re: draw through turbo carbon seals?
clyons8 Posted on: 2014/9/25 0:06
Carbon seal. Must.
I found this guys explanation convincing enough to do it. There is a lot of other info out there.
