Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Hazard and Turn Signal Wiring
Sumith
Posted on: 2014/10/7 6:37
Hi Guys
Does Hazard and Turn Signal Shares the same Flasher in b210 or have different Flasher for each function ? any Clue ? thanks regards sumith
#2
Re: Hazard and Turn Signal Wiring
Posted on: 2014/10/9 3:42
#3
Sumith
Posted on: 2014/10/9 4:14
hI dd
Ok, I have One Flasher should be confirmed since it is JDM Model , i will Use the Same Flasher , I have Rewiring For that Because I don't Have Hazards Switch on my Steering Column Cover(It is broken), Small Issue Turn Signal is connected IGN Supply, d is hazard the same or Should be able turn on without ignition on ? thanks regards sumith You can view topic.
