#1 Jetting Twin Dellorto's DRLA in A15
andrep Posted on: 2017/2/17 1:08
Hi all!
I'm in the process of building up an A15. It'll feature some modifications as: Ported Intakes (2.25mm), lowered head (0.6mm), lightened Flywheel (5.8kg), Fast Road Camshaft and 2 Dellorto DRLA 40's!
I'm in the process of jetting the carbs, but theorically, it all just seems soo confusing...
From this tutorial: http://www.nzdatsun.com/forums/viewtopic.php?f=17&t=342
I got this setup:
Dellorto DRLA 40's
Venturi: 33mm
Main Jet: 132
Air Corrector: 180
Emulsion Tube: 7772.6
Iddle Jet: 40 / 7850.1
But then started reading more, and checked some other jetting engines, and It all just seems confusing.
Can some jetting expert guide me through a "safe" starting point to jet my engine?
#2 Re: Jetting Twin Dellorto's DRLA in A15
ddgonzal Posted on: 2017/2/17 2:07
The most important thing is: Venturi Size. All the other setting depend on it. Jetting for 32mm venturis differs from jetting for 28mm venturis
#3 Re: Jetting Twin Dellorto's DRLA in A15
andrep Posted on: 2017/2/17 22:08
Well, I used the chart above to calculate that I might need a 33mm venturi, but what about the other jets? Thats the difficult part
#4 Re: Jetting Twin Dellorto's DRLA in A15
ddgonzal Posted on: 2017/2/17 22:25
That's the easy part. For ballpark correct A/F ratio:
* main jet is 4x venturi size = 132
* air jet is main jet + 50 = 182
Now for the hard part: transitions ... when the throttle changes, how much fuel it requires it differs with different engines and camshafts. These seem like a good starting point:
* Emulsion Tube: 7772.6
* Idle Jet: 40; air bleed: 7850.1
To be "safe" means make sure the A/F ratio never goes lean (lean = above 14.7:1). That means starting rich, later when you tune the carburetor you'll lean it down to best performance. Best full-throttle power: 12.5:1 ratio. Best cruise: 14:1. Best economy @ level cruise: around 15:1
#5 Re: Jetting Twin Dellorto's DRLA in A15
andrep Posted on: 2017/2/17 23:16
Well, that's basically what I concluded from above.
So, is that a safe starting point for my tuning?
#6 Re: Jetting Twin Dellorto's DRLA in A15
ddgonzal Posted on: 2017/2/17 23:18
Yes. Be careful while you are tuning, don't let the engine ping/rattle
