Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Datsun A12 Oil sandwich plate
Luigi
Posted on: 2017/3/31 15:54
Hi!
Datsun 1200 takes a traditional spin-on oil filter with 76-82 mm diameter and threads of 3/4-16 what kind of sandwich oil plate that i must buy? This one says its universal? http://www.ebay.co.uk/itm/33133294206 ... 015056&cp=1&sojTags=bu=bu Please give me ideias? A 10 row oil radiator will fit ok with the stock oil pump? or i must buy a difrent spring or change the internal component with a L Series? Mant thanks on advance for all your help Luis
#2
Re: Datsun A12 Oil sandwich plate
Posted on: 2017/4/1 5:01
The Ford V8-style sandwich plate is the one you want. Actually any 3/4-16 thread unit works. It's one of the few non-metric parts on an A-series engine
http://www.google.com/search?q=Transdapt+1313
#3
Luigi
Posted on: 2017/4/7 10:18
Hi!
Can i use a oil radiator 10 rows with a stock oil pump? Or i must change the spring? It is enough make this simple change? Please let me know what i have to do, to keep the oil pressure in perfect conditions? http://www.datsun1200.asia/category/select/pid/8823/language/en is not necessary to grind any part of engine to set up the oil plate sandwich? Many thank on advance Luis
#4
Luigi
Posted on: 2017/4/8 16:02
Anybody let me know if this item will fit perfect?
https://derale.com/products/fluid-cool ... -16-filter-threads-detail Thanks Luis
#5
Posted on: 2017/4/8 19:45
It works with stock oil pump
No grinding is needed for the Transdapt 1313 You can view topic.
