#1 Starter Trouble
Sumith Posted on: 2018/6/4 12:20
Hi Guys
I have a problem with my b210 starter sometimes it clicks the solenoid doesn't rotate the engine specially when cold and rainy weather with my ignition key.
When i jump a wire from Main Starter wire to the solenoid it works immediately, then after i can start it with my ignition key.
what would be the reason ???
thanks
regards
sumith
#2 Re: Starter Trouble
ddgonzal Posted on: 2018/6/4 20:54
It could be the ignition switch -- I had that happen on a B310 (clicked but would not rotate engine)
#3 Re: Starter Trouble
ddgonzal Posted on: 2018/6/5 9:50
You can test the Ignition Switch by unplugging it, then test
* OHMS between the Start wire and the Battery wire
or
* jump S wire to B wire at the female connector to see if the engine spins
Battery wire is usually White
Start wire is I think Black/Yellow
#4 Re: Starter Trouble
Sumith Posted on: 2018/6/7 10:05
Hi DD
Thanks i will check it
regards
sumith
