Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
how do i make my head flow better
jimmy
Posted on: 2003/2/6 21:59
now can i make my a14 head flow as well as a gx head because i cant find one
#2
Re: how do i make my head flow better
1200rallycar
Posted on: 2003/2/7 8:17
is it round or oval inlet port, the one you have i mean, a-14's came with both
#4
jimmy
Posted on: 2003/2/7 19:00
hay 1200rallycar. Thay look to be round. There is
alot of space between them. And can i safly drill and tap it for more studs if i seal the threds
#5
datto_dave
Posted on: 2003/2/8 2:20
does anybody know if it is possible to get a stud kit for the head? have studs instead of bolts.
thanx DAVE
#6
1200rallycar
Posted on: 2003/2/8 3:13
first thing i would be doing would be getting an oval port head off an a-14 for it, it will be a great improvemnt in flow without modification, i think, not sure but it may even have larger valves in it too
as for the studs ive never done anything like that so i couldnt really tell ya im, thinking your reply will read "a-14's are too rare to find an oval port head" or something to that effect but i really think its the way to go
#7
rally-a-coupe
Posted on: 2003/2/8 7:06
no Not an A14 head get an A15 head as they have a lot more meat on the gasket face so you cane get the head planed for high compression without getting hotspots
#8
Posted on: 2003/2/8 7:08
oval port heads are the common A14 head in the US.
jimmy, the round port heads have perfectly round ports. If you take the intake manifold off it will be easy to tell.
#9
jimmy
Posted on: 2003/2/8 17:47
the ports are round is that good or bad
#10
b310gx
Posted on: 2003/2/8 22:23
arp make a stud kit for both a12's & a14/15's.haven't found anyone in aus with one in stock yet,but check out www.wholesaleperformance.com.au for part numbers.they're in brisbane,they're an importer,& the site has a link to arp.
