#1 A14 carb on an A12
datto_dave Posted on: 2003/2/20 8:26
can any one tell me wat an a14 carb and intake manifold would be like on an A12?? i currently have a weber 32/36 dgav and it uses a hell of a lot of fuel and i cant put the a12 carb back on as i smashed it with a hammer cos i hate them also would i be better off working an a14 head for my a12 rather than the a12 head?
thanx
DAVE
#2 Re: A14 carb on an A12
b310gx Posted on: 2003/2/20 9:48
the a12 carb without the pollution stuff was the best of the stock carby's,so it's a pity that you 'broke' it when you took it off.so,the next question is,what jets you running in the dgav,not stock 2 litre cortina ones.i'd try around the 115 main jet mark.oh & new jets are something like $3 each from Carbarettor Services in sydney,so you should be able to do some cheap fiddling,because any carby place should have a range of new ones.
#3 Re: A14 carb on an A12
dimlight65 Posted on: 2003/2/20 17:00
I'm going to have to agree with b310gx in that if the Weber is tuned properly, it should run circles around the stock Hitachi carbs. I could be wrong though. Give the A-14 carb a go and if it doesn't work, tell us and we'll all know!
#4 Re: A14 carb on an A12
ddgonzal Posted on: 2003/2/20 17:21
B310gx is right, downsize the jets in your Weber and you'll get back your economy. I recommend getting a 'jet kit' with a selection of jets, so you can fine-tune it. You'll be glad you did.
The A14 and A12 carbs are both Hitachi 306s.
Will the A14 intake manifold fit your A12? Take a look at this:
Intake manifold comparo
#5 Re: A14 carb on an A12
datto_dave Posted on: 2003/2/21 7:42
ok then cos i am running 140/140 jets at the moment. the carby is from a cortina race car. the jets were 180/255 i ran it like that for a day and it absolutely hammered. it also used 3/4 of a tank to go 50 k's
thanx guys
DAVE
