Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
GOOD OR BAD???
noisy13b
Posted on: 2003/6/12 7:34
hi guys,
just wanted to throw somthing at you's......do you think a L20B would go ok in a datsun 1200 ute???
#2
Re: GOOD OR BAD???
DVLDAT
Posted on: 2003/6/12 8:32
hay answer u question my datto still got standard motor in cause i got tha ca18det gettn a full rebuild and i reckon that if u got tha money and time why not get a ca18det if $ problem i deffenetly go for tha l20b will go hard as they go hard with anymotor cause they only wigh 700kg
#3
Re: GOOD OR BAD???
noisy13b
Posted on: 2003/6/12 8:44
thanks for the input i agree but i spoke to a other guy and he reckons nah it will be a peice of #### making the car ro heavy at the front but the way i think about it is the motor weights just about the same as a CA18det and later on i can slap a turbo setup, yeah your right the $ is stoping me from going for the CA18det
#4
Re: GOOD OR BAD???
Peddler
Posted on: 2003/6/13 2:52
much of a muchness Dude....... L20 is a strong engine and performer when you start to play around with them. I still recon tha dollar for dollar adn bang for your bucks you cant go past a CA18 !!!!
What it comes down to is how much you wanna spendn and what you wanna do with the car ???????????? Cheers Peddler
#5
Re: GOOD OR BAD???
Posted on: 2003/6/13 5:22
Do you think a L20B would go ok in a datsun 1200 ute?
Yes. It's no heavier than a CA18DE. See the article What's the best engine to put into a 1200?.
#6
Re: GOOD OR BAD???
noisy13b
Posted on: 2003/6/13 7:57
well i reckon the L20 should go ok the main reason im going for the L20 is it is way cheaper then the CA18det and will only cost like $1000 to install so thats pretty cheap for a complete conversion and i thought maybe later on i can dump a T3/T4 with a 45mm weber
