Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#9
Re: Cylinder-head flow??
Datsun100ATurbo
Posted on: 2004/1/12 6:21
Thanx guys, I will port a A15 head soon....... I will post the flowfigures when it
#8
sticks
Posted on: 2004/1/9 8:16
These are some flow figures i acquired from Mick Atholwood a couple of years ago.The head was an oval port A15.
Inlet valve 37 mm Exh valve 33 mm Chamber 26.5 cc Figures are at 10" and CFM Lift Inlet Exh .100 35 25 .200 66 42 .300 78 53 .350 81 58 .400 83 60 .450 83 62 .500 84 63 He reckoned the Inlet at .450 was good for143 HP and at 500 was 144 HP. Hope this is of some interest.
#7
Posted on: 2004/1/9 7:10
It's only common among racers (of certain types of racing) as far as I know. I don't know anyone here who's ever had heads flow-tested.
I thought that Feral had posted some flow information on his A13 engine ...
#6
1200rallycar
Posted on: 2004/1/8 8:02
flow tests arnt common as far as i know, and neither is spending big money on porting
#5
Datsun100ATurbo
Posted on: 2004/1/8 6:58
Where are every a-series gurus herearound
, have you all switched to CA18DET or haven
#4
B120dat
Posted on: 2004/1/7 11:19
Ports: - 39 x 31 mm biased Inlet, 31 x 28.5mm exhaust, Ports by Hiflow matched to GX gasket. flow benched.
Valves: IN: 35mm, EX 29mm Nissan narh flow test after the job, the port job was only mild but done by a guru datto master Errol knows.
#3
Datsun100ATurbo
Posted on: 2004/1/7 11:11
What size valves have you got there?? Was the head flow-tested before portjob?? Bye the way, Nice car and engine setup!!
#2
B120dat
Posted on: 2004/1/7 9:46
this is my flow rating for my head, its a A12gx head, stock valves etc, with bit of porting. give you some idea
http://datsun1200.com/modules/myalbum/photo.php?lid=1294
#1
Datsun100ATurbo
Posted on: 2004/1/7 9:24
Does anybody know how much a original A14 head (oval intake ports but not GX) flows. I am also interested in what flow figures/results you have got out of your modified cylinderheads. I will try to get as good flow as possible with stock valves, because it
