Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#4
Re: A15 valve clearance
Buff
Posted on: 2004/2/10 8:14
I have an A15 Engine Manual and will confirm that they are:
0.35mm or (0.014") both inlet and exhaust when hot Also just in case anyone wants to know Inlet valve sizes compared to A12: A15 Inlet - 37.0mm A12 Inlet - 35.0mm A15 Exhaust - 30.00mm A12 Exhaust - 29.00mm Your Welcome....................
#3
Posted on: 2004/2/10 7:27
A15 might have a different spec (though I doubt it). In any case with a stock cam, the A14 specs can be used safely. See the tune up article.
#2
dattodevil
Posted on: 2004/2/10 7:15
A12, Hot intake and exhaust 0.35mm (0.014in) I presume the A15 should be the same
#1
A15 valve clearance
noyski
Posted on: 2004/2/10 2:36
hi there,
do any of you guys have specs for valve clearance on an A15 engine? Im trying to tune up my A15, problem is I dont know whats the correct clearances for the exhaust and intake valves,when its hot and cold...thanks.... You can view topic.
