#3 Re: Need a weber carb and manidold!!
smj_92845 Posted on: 2000/8/29 5:07
Thanks Andy. I ll try taking the carb apart again and cleaning out those little nozzles again and see what happens. Yeah I m interested in the weber carb place u mentioned. I
m in the Southern California Area. My Email address is DodgeBoye@aol.com Thanks Steve
#2 Re: Need a weber carb and manidold!!
Errrnstak Posted on: 2000/8/29 4:40
First I would make sure the fuel pump is pumping the gas. Easy way to test that is by disconnecting the fuel line by the carb and cranking it over, if gas squirts out, it's good. If the
carb has been recently rebuilt, you should be able to take it apart and reuse the gaskets. I would guess that maybe something is clogged in either the float bowl or one of the little
nozzles or jets gas flows through. I would take it apart and spray carb cleaner through all the little holes, nozzles, and crevices that air or fuel might flow through. Good luck! I know of
a place in the US that you can get a Weber 32/36 DGV kit from if you're interested. I think they're around $350.
-Andy
#1 Need a weber carb and manidold!!
smj_92845 Posted on: 2000/8/29 2:58
I have an A-14 in my 1200 from a B-210. Recently
it quit running( starts up briefly and dies. The Hitachi carb sight glass indicates the float bowl is full but somehow the gas isnt getting to the engine. I know, because when i squirt
gas down the carb throat it does fire up. I m fed up with this crappy Hitachi and rather than trying to "rebuild "it again I was wondering if u guys had any suggestions what may be wrong
with it or better yet if u hsve any used Weber carb and mnifolds for sale. E-mail me if u have anything.
Thanks
Steve
